Re: tire size
Posted by mkirsch on May 15, 2012 at 05:21:10 from (64.80.110.75):
In Reply to: tire size posted by randy2 on May 14, 2012 at 14:09:19:
If the duals are cheap enough you could get them and look for a clapped-out set of 18.4's to put on the rims.
Heck, you might be able to get away with the 20.8's if you run 'em soft.
The 20.8's are significantly taller than the 18.4's unfortunately. It works OK when the 20.8's are on the inside, but I gotta imagine having the bigger tires on the outside would cause undue strain on the axles. If they're clamp-on duals, even worse...
