Re: Farmall Super C- antifreeze in engine oil
Posted by Farmboy856 on May 15, 2012 at 06:09:06 from (192.131.99.132):
In Reply to: Farmall Super C- antifreeze in engine oil posted by M Nut on May 15, 2012 at 05:56:24:
My first guess would be the large O-rings around the sleeves/liners, but having it appear on the cam MIGHT indicate a cracked block, but that is a big MIGHT. Those O-rings are more than likely the culprit. I've seen it many times.
