Re: Farmall Super C- antifreeze in engine oil
Posted by El Toro on May 15, 2012 at 06:35:22 from (108.3.225.57):
In Reply to: Farmall Super C- antifreeze in engine oil posted by M Nut on May 15, 2012 at 05:56:24:
Since there's no leakage around the new sleeve seals you probably have a cracked block. I would look for another engine block and have it magna-fluxed. There should be plenty of the 354898R1 blocks around. Hal
