Re: Farmall Super C- antifreeze in engine oil
Posted by Red Dave on May 15, 2012 at 06:59:16 from (66.216.141.163):
In Reply to: Farmall Super C- antifreeze in engine oil posted by M Nut on May 15, 2012 at 05:56:24:
It might be a cracked block, but it also might be a head or even a head gasket problem.
I wouldn't assume that it is a bad block until I exhausted all the easier (and cheaper) to fix possibilities.
Did you use sealer on the head gasket and do the required retorque?
The very first thing I would do is run it until it is warm, then retorque the head to 80 foot/lbs. If you are lucky, that might solve it.
