Re: Super H Governor
Posted by CoopertownBob on May 15, 2012 at 08:23:25 from (74.51.5.84):
In Reply to: Super H Governor posted by metalmender on May 14, 2012 at 17:15:59:
Others have covered most of the potential issues, but to get back to the kiss principle, have you checked the idle speed adjusting screw to make sure it is not turned in too far? I mean the one on the carb.
And while you have it back off checking the throttle plate, check to see if the butterfly will even close. If the plate is in the shaft backwards, it will sometimes prevent the throttle from closing some or at all. The plate is not round, but somewhat oblong. A very difficult thing to notice if you are not looking for it.
If the tractor was idling fine before the rebuild, then I would say the gov is adjusted correctly and issue is in the carb or the linkage.
This post was edited by CoopertownBob at 08:30:20 05/15/12 3 times.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
