Posted by Owen Aaland on May 15, 2012 at 10:41:18 from (216.47.35.144):
In Reply to: New 1086 owner posted by Mike1972chev on May 14, 2012 at 07:01:22:
Either the sender or the wire going to it are shorted to ground. The sender is located in the head above the alternator behind the water filter bracket.
Disconnect the wire from the sender and see if the gauge still goes to full hot. If it makes no difference then check for a damaged wiring harness. The last possibility would be the gauge itself has internal problems
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
