Re: Farmall Super C- antifreeze in engine oil
Posted by rustcollector on May 15, 2012 at 11:25:46 from (166.249.194.0):
In Reply to: Farmall Super C- antifreeze in engine oil posted by M Nut on May 15, 2012 at 05:56:24:
When you have exhausted all the suggestions below, including a new head gasket with a good coating/sealant and properly torqued, I would try a good stop leak compound before discarding the block. Slight leaks can be stopped and not be a problem.
