Super M liftall and drawbar ??
Posted by gab on May 15, 2012 at 18:08:38 from (50.44.11.139):
Do you need to pull the pump out of the liftall and then stick a bar in the gears to get the nut off the shaft to repl the seal. The pict. in the I&T manual looks like you stick a small bar in the gears through a hole in the case.
Also I noticed on another Super M that the draw bar axle mounts are turned over from the way mine are which would raise the drawbar a couple inchs probably. The operators manual pictures and the parts book shows the brkts. flipped from the way they are on my tractor. I can tell by the pitting on the top eye bolts and lack off it on the bottom bolts that this is probably the way it always was and did'nt see any thing in the op manual about turning the brkts. for any reason. So which way should they be .
Today's Featured Article - Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
