666 hydraulic issue
Posted by Steve 101 on May 15, 2012 at 19:45:23 from (67.7.127.52):
My 666 gas has app. 1600 lbs. hydraulic pressure, when testing with guage, I hear the pump whine some and the pressure jumps to 1600#, then drops to about half of that pressure, and then repeats the higher pressure again. This happens about 8-10 times a minute. Pump filter is fine. Do I need to replace pump?
