What you say does make a lot of sense now that I think it through. I could have just followed the directions and been fine - but I prefer to actually KNOW why I'm doing it that way.
The key was that it fires every half revolution -That's obvious when you do the 3rd grade math - 4 cylinder engine each firing once every 2 revolutions.
(But only obvious now that you pointed it out!)
So here's how I'm reading it:
Set mag ready to fire on 1 - put it in the block. Don't worry about exactly when it's going to click - just make it greatly retarded so you can be sure to make it click manually on the last step.
Rotating the engine one half revolution makes it fire on 1 (late) - and go to cyl. 3.
Another half revolution would fire late on 3, and get it ready for cyl. 4
1 and 4 are again at tdc, but now 4 is on its compression stroke.
Go slightly past tdc since you want the mag firing a little AFTER tdc to be safe - especially when hand cranking it.
Advance the mag by hand until it clicks, and tighten it down there. That's where it'll actually fire in relation to the piston in 4 - slightly after tdc.
And obviously if it's timed properly for one cylinder it's timed for all.
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
