i agree with the fuel problem. peek down in the fuel tank and see if there is any junk in there. i would drain the tank and flush it out good. then clean the sediment bowl and blow that out real good. if you have an aftermarket in line fuel filter on the tractor, get rid of it, unless it is a full flow filter for a gravity flow system. (napa 3031 or 3032 are two full flow models). also try running the tractor with the gas cap loose. could be a venting issue also. also, try running the engine with the air cleaner pipe dis-connected from the carb. could be a plugged up air cleaner too.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
