Re: farmall h fuel issue
Posted by WSJ on May 16, 2012 at 09:16:04 from (216.139.53.65):
In Reply to: farmall h fuel issue posted by dave innerebner on May 14, 2012 at 14:23:11:
You can take the shotgun approach and start replacing everything or diagnose the problem.
You can measure the mount of gas flowing to the carburetor by removing the fuel line at the carb.
This will also give you access to the screen inside the carb for cleaning. When the gas in the trank is low, the pressure
at the carb will be about 0.25 PSI. When the gas tank is full, the pressure will be about 0.4 PSI.
