Re: super m electrical problems need help
Posted by Bob M on May 16, 2012 at 13:13:46 from (74.67.189.51):
In Reply to: Re: super m electrical problems need help posted by John T on May 16, 2012 at 12:07:10:
Agree John! Problem sounds like a short in the starter.
This is what happened to mine:
The Super M is equipped with a saddle type manual starter switch perched directly atop the starter. The starter's power terminal is a simple copper button poking thru the motor frame. It is insulated from the frame by a bakelite or nylon bushing.
As the terminal button gradually wore down it caused the starter switch contact bar to arc and run hot. This melted the button's insulating bushing and caused a short. It also burned out the starter switch and caused the battery cables to overheat.
Fix was to have the starter shop replace the terminal button and insulator - about $40. This and a new saddle switch had the starter again working perfectly.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
