Posted by BigTone on May 16, 2012 at 14:58:40 from (166.248.3.74):
I have the foot activated starter button (12 volt generator/battery) and Ive replaced the button twice and now the button is sticking and wont disengage on its own.
I am going to get the H starter button mount so I can put it next to the light box. What i need to know is can I route the cables down through the original starter button hole to the starter/battery or do I have to run them to the left? I guess im afraid that the length of the battery cables will to long and ill loose some juice if i run them through the bottom hole...I just kind of wanted them out of the way. any advice is appreciated
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
