Re: Engine Rebuild
Posted by Andrew Z on May 16, 2012 at 15:56:50 from (64.252.115.167):
In Reply to: Engine Rebuild posted by Tim Workman on May 16, 2012 at 14:42:24:
Also 80 ft lb is the proper updated torque spec, not 65lb
Andrew
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
