Re: How does a TA work?
Posted by Kevin Meier on May 16, 2012 at 19:43:08 from (174.253.133.122):
In Reply to: How does a TA work? posted by Senator on May 16, 2012 at 18:58:07:
A ta has 2 clutch packs that run by hydraullics 1 for directions drive which runs through the quill and a series of gears. The ta clutch pack runs through a differentiation
series of gears. The clutch packs are split through 3 seal rings on the shaft. When the ta side fails it falls back on the sprag which os the part hhat keeps your tractor from freewheeling. Kinda hard to explain without showing you in person.
