I've occasionally seen or heard of a slightly strange serial prefix on the Super A series of tractors. I don't think it is impossible for there to be a few that were simply mis-stamped.
I believe the sequence numbers were pre-stamped. Then as the tractors were built, the appropriate prefix was stamped. If a mis-stamped plate was discarded, the sequence number would have also needed to be "scrapped" (skipped from the sequence numbers). I suspect there would have been a strong temptation to let some errors slide on through.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
