Re: 1941 h revisited from last week
Posted by CoopertownBob on May 16, 2012 at 21:19:21 from (74.51.5.80):
In Reply to: 1941 h revisited from last week posted by jim warehime on May 15, 2012 at 17:46:48:
It's not drawing enough fuel for some reason. That flapper in the manifold just makes it run hotter to atomize the distillate properly. If it atomized the gasoline too much, it would run great just be down on power, but get the best fuel consumption you ever saw! If you still have the other manifold, and it is in running condition, it would be a quick 15 minutes to install it and run the engine to see if that makes any difference.
Is the manifold itself stopped up or otherwise not allowing the engine to draw properly? What about the valves? Any sticking, etc?
When you say it will only run on choke, is that at idle or working speed? Can you spray ether into the intake tract and make it run with the choke off? That would narrow it down to a fuel delivery issue. When rebuilding the carb, did you run a drill bit through the jet to increase its size? What about the venturi, did you install a larger one or otherwise increase the size of it?
To expand on what rustyfarmall asked, did it run fine with the new magneto installed prior to the carb being removed the first time? And for that matter, did it run okay prior to this recent work being performed?
And to stick to the kiss principle, is the fuel tank cap's vent hole stopped up? I had my SM stop in the middle of a parade one time over that simple little issue. An old-timer there asked me what the last thing I changed was, I told him I had just put on a new fuel tank cap with a gauge in it. He said unseal it and try to start it. It opened with a very slight sucking sound, then she fired right back up. Later back at home, I took the cap apart and opened up the vent hole. Works fine now.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
