Re: rrrg - another magneto question.
Posted by JRSutton on May 17, 2012 at 07:49:45 from (75.130.109.233):
In Reply to: Re: rrrg - another magneto question. posted by James Williams on May 17, 2012 at 05:38:49:
again - the problem is that it's NOT fine.
It's firing too close (or aparently a split second before) TDC.
The engine DOES kick back occasionally when hand cranking.
I need to retard the mag, but it's already in the fully retarded position.
