Re: Cubs clutch (I think)
Posted by wisbaker on May 17, 2012 at 08:15:58 from (207.118.181.106):
In Reply to: Cubs clutch (I think) posted by Farmallb on May 17, 2012 at 04:55:47:
My Cub Cadet "120" (70 with a Kohler 301) didn't want to shift and grinded when I tried to put it in gear when I first got it. Once I bolted the motor onto the frame the problem went away. The real PIA was it didn't have any bolts holding the motor on because someone prior to me stripped all the threads out of the holes in the bottom of the pan. Can you say Heli-coil? I knew you could
