Re: Farmall 300 update, sleeve question
Posted by El Toro on May 17, 2012 at 10:11:21 from (108.3.225.57):
In Reply to: Farmall 300 update, sleeve question posted by Zachary Hoyt on May 16, 2012 at 18:34:39:
For $332.00 you can get a new set of sleeves w/pistons and rings from this forum. Do it right the first time. You will be glad you did. Hal
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
