Re: rrrg - another magneto question.
Posted by JRSutton on May 17, 2012 at 12:22:26 from (75.130.109.233):
In Reply to: Re: rrrg - another magneto question. posted by John T PS on May 17, 2012 at 10:55:37:
Hope you enjoy the show.
I bit the bullet and advanced the lag angle to the full 35 degrees.
I just put the mag on the tractor - and it at least "feels" right.
I can't try starting it till I get a few more parts done.
The mag now sits where I would expect it to. It's roughly in the middle of the swing angle. I've got it snapping a few degrees past tdc.
So I'm thinking this was probably the right thing to do - of course I won't know till I try running it - but for now I'm happy.
Thanks once again to all that helped - I will follow up in a few days when I actually try firing it up.
