Re: Odd problem with my BA
Posted by CoopertownBob on May 17, 2012 at 15:00:44 from (74.51.5.10):
In Reply to: Odd problem with my BA posted by John A. on May 17, 2012 at 11:37:53:
old said: (quoted from post at 14:37:53 05/17/12) Ya it is part B part A so that is why I call it a BA. Any how I was out mowing hay and right after I did a couple donuts on a copper head it went another 25 feet or so and dies. Has fuel and spark from the coil wire. Checked spark at the plug wires and no spark. I have not gone back out to see if another rotor or cap will fix it or not. Have a couple old rotors laying around and hope the cap off a MM RTU will fit if the rotor does not fix it. It was running real nice then all at once just stops like some one turned it off. Will post back later when I find the problem
Look for fang marks on one of the tires. Sounds like your tractor done got snake bit! :lol:
Seriously though, maybe you stirred up some sediment in the tank and it stopped up the line, the sediment bulb or even the carb itself. I know you said it has gas, but is it getting into the carb?
This post was edited by CoopertownBob at 15:04:36 05/17/12.
