Re: Odd problem with my BA The fix
Posted by pete 23 on May 17, 2012 at 18:05:35 from (74.32.231.176):
In Reply to: Odd problem with my BA The fix posted by old on May 17, 2012 at 17:47:17:
When the rotor fails it usually has a carbon path either around the outer edges of the rotor or right down through it to the dist shaft. Hard to tell why but no doubt excessive voltage requirement of jumping from rotor tip to dist cap would be a likely suspect or the center contact point in cap as well. A little moisture on rotor would make it easier to form this carbon track. While on this subject, most caps that are supposedly cracked are actually carbon tracking and appear to be a slight crack.
