Having coolant coming out of the cap or overflow is pretty normal on a thermo siphon system. If you had just a bit over full radiator combine with 30mins of run time youll get that result. When you run it again make sure the coolant level is at the proper level and check to see if the lower water pipe is warm but not so hot its uncomfortable to touch, the top line should be warmer.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
