Re: Amp Gauge after 12 volt conversion
Posted by TylerFarmallH on May 18, 2012 at 06:46:29 from (69.71.1.1):
In Reply to: Amp Gauge after 12 volt conversion posted by mkirsch on May 18, 2012 at 06:16:38:
I didn't read about removing the voltage regulator when coverting to 12 volt. It's necessary? I disconnected the blue ground wire and tested it with no difference. The hot wire does run through both the diode and the regulator...
