Re: 560's
Posted by J.J. from Afton on May 18, 2012 at 07:20:44 from (99.160.142.135):
In Reply to: Re: 560's posted by bob7337 on May 18, 2012 at 03:56:53:
The ring and pinion ratios are different between the rowcrop and the standard to make up for different wheel sizes, I wanna say it is one or two teeth more on the ring in the standard to make up for smaller rear wheels. You would have to check online to see about the 1st through 5th 4th gears as I would suspect those differ as well. I had to use the ring and pinion out of a rowcrop to replace the ones in my 560 standard so it goes a little slower but no huge difference.
