Re: Amp Gauge after 12 volt conversion
Posted by TylerFarmallH on May 18, 2012 at 11:25:12 from (69.71.1.1):
In Reply to: Amp Gauge after 12 volt conversion posted by mkirsch on May 18, 2012 at 06:16:38:
Thanks so much. I had two regulators and a bad amp guage. I removed the regulator used for the generator everything is working fine now. Thanks everyone.
