Re: M steering box
Posted by rustyfarmall on May 18, 2012 at 14:29:58 from (67.55.162.174):
In Reply to: M steering box posted by docs69 on May 18, 2012 at 12:55:50:
The shimmy comes from worn out bushings, bearings, and the vertical shaft itself. You're going to get a whole bunch of answers on how to cure it, including the theory that running one tire under-inflated will cure it, but the only way to fix it right so it stays fixed is to replace all of the worn out parts.
Once everything is back up in top shape, you will think you are driving a brand new tractor.
