Posted by Bob M on May 18, 2012 at 19:30:31 from (74.67.189.51):
In Reply to: MD no spark posted by IAtractorKid on May 18, 2012 at 19:12:45:
Is the magneto making a loud "snap" every 1/2 revolution of the crank? If not the mag impulse coupling is not working. You'll need to remove the mag and clean/oil the impulse.
If the impulse is snapping, next then disconnect the wire running from the manifold switch to the mag. Could be the manifold shorting switch has stuck closed and is preventing the magneto from sparking.
If that doesn't do it, remove the mag cap and clean/re-gap the breaker points (set the points to 0.013)
Still no spark? Time to get in touch with a reputable magneto repair shop!
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
