Posted by SadFarmall on May 18, 2012 at 19:33:36 from (118.209.141.41):
In Reply to: MD no spark posted by IAtractorKid on May 18, 2012 at 19:12:45:
First thing to do with an H4 magneto is to remove the coil cover (four cheese head screws) and check the contact between the coil and the strip, which connects the high tension wire, leading the centre of the distributor cap. There is often a bit of corrosion or copper sulphate build-up here, which kills the spark. If this does not work, then you need to start pulling the magneto apart. It is highly desirable to have an Owner's Manual and/or Workshop Manual to help you do this. The magnetos are not difficult to work on, but without an exploded diagram and instructions, it is easy to set the magneto timing incorrectly.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
