Re: 300 u with 2001 loader can't lower bucket under control
Posted by pete 23 on May 18, 2012 at 20:32:48 from (74.32.231.176):
In Reply to: 300 u with 2001 loader can't lower bucket under control posted by realolman on May 18, 2012 at 17:37:22:
You should be able to lower as slow as you want
and the engine may well be laboring. If you move
lever far enough so it quits laboring you are
opening the spool valve quite a bit. Some valves
have feathering slots in them for better control
and yours may not have them. The laboring is
caused by the regulator port being opened before
the return port is opened and if you do not need
down pressure you can turn the spool on the valve
to single action for lowering. The cover on valve
is marked S and D with a roll pin to control max
movement either way. You may possibly have a check valve,( seperate block mounted on aux valve) but I doubt it . That could give you problem with feathering drop. I have taken the balls out of a lot of them on loader tractors for convenience.
