Posted by Brownie 450 on May 19, 2012 at 04:05:58 from (66.43.241.198):
In Reply to: MD no spark posted by IAtractorKid on May 18, 2012 at 19:12:45:
Easiest thing to check is to pull the dist cap & check that the spring-loaded carbon button isn't worn down to the nub/ missing. Then check for spark from the mag "output" using a new wire to ground. Last thing to do is take the mag apart.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
