yeah - definitely sounds like your floats/float valve.
If it's dripping, the floats aren't closing the gas off into the carb.
Generally there are 4 things that can cause that.
1st the easiest - the floats are sticking in place. A few sharp raps on the side of the carb from something not too solid (like a screwdriver handle) usually frees them.
2nd - floats have a leak. If you've just had it professionaly rebuilt - one would hope that's not the issue.
3rd - Junk in the float valve - you might get by with blowing a little compressed air or carb cleaner through the gas inlet. But likely you need to remove the floats/valve and wipe it down.
4th - floats aren't adjusted properly - again one would hope that's not the problem since it was just rebuilt.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
