Re: 42 H Slow Gear Oil Leak Behind Lift-All
Posted by The Red on May 19, 2012 at 06:39:13 from (69.246.205.0):
In Reply to: Re: 42 H Slow Gear Oil Leak Behind Lift-All posted by Sapper55 on May 19, 2012 at 06:27:28:
Yes and yes. the lower counter shaft end I believe you screw off so have it in gear. Then that carrier has 3 bolts holding the seal. If I recall correctly the upper seal is in a carrier assembly that has 3 bolts to remove it. You will want a new gasket for both carriers. Parts on this site are available. I personally use Carter & Gruenewald who carries genuine Case parts. 608-455-2411. Ask for parts.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
