The battery that is pictured is an 8 volt so yep still a 6 volt system with a band aid fix for poor starting. As for antifreeze I would mix my own and save you from buying half a gal of water at $3 per or more. As for a 12 volt battery hurting it no it will not unless you leave it on for a long time or run it a long time and even then all that will happen is you burn the points and or burn out the coil. Me I would check for spark which most likely is the problem and it needs the points cleaned and or replaced since just from sitting they will corrode and stop working
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
