Re: 42 H Slow Gear Oil Leak Behind Lift-All
Posted by jbp on May 19, 2012 at 10:44:38 from (64.57.160.204):
In Reply to: 42 H Slow Gear Oil Leak Behind Lift-All posted by Sapper55 on May 18, 2012 at 22:23:41:
Just put my 47 H back together yesterday for the same problem. Not a bad job at all , if you have a floor jack make a wood cradle to put between the lift-all and the jack cradle for lowering the lift. Everthing else is pretty straight forward. Had to use a speedi-sleeve on the input yolk as there was a groove where the seal had been running. You might want to check the ball bearing on the input shaft for play too. Mine was loose so replaced it.
Joe
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
