Re: Questions about getting Grandpa's H to start
Posted by El Toro on May 19, 2012 at 11:03:56 from (108.3.225.57):
In Reply to: Questions about getting Grandpa's H to start posted by dstates on May 19, 2012 at 10:33:17:
Take your volt meter along and with the points open and your ignition switch on check to see if you have battery voltage at your coil. Take some 320 wet or dry along and rub those points until shiny. Also take a gallon of raw antifreeze along with an clean empty gallon milk jug. That will give you 2 gallons of 50/50 mixed antifreeze. Do the mixing before filling the radiator. Hal
