Re: Questions about getting Grandpa's H to start
Posted by John V. on May 19, 2012 at 11:11:17 from (198.228.226.59):
In Reply to: Questions about getting Grandpa's H to start posted by dstates on May 19, 2012 at 10:33:17:
Good story, I recently did the same with my Grandfathers H.
Here is my advice as learned from the folks on this board. On
a six volt system it is absolutely key that all your wiring is
good and your connections are clean and shiny. When I
replaced the wiring harness and cleaned the connections
mine turned over faster than ever before. Secondly, clean out
the sediment bowl and fuel line. Mine was blocked with little
bits of debris. We took it off sprayed it with carb cleaner and
then blew it out with an air hose.
