Re: Questions about getting Grandpa's H to start
Posted by evilboweviel on May 19, 2012 at 11:48:54 from (75.185.55.222):
In Reply to: Questions about getting Grandpa's H to start posted by dstates on May 19, 2012 at 10:33:17:
dump water in it to get it moved, no need to waste antifreeze until you get a chance to fix what leaks you want to, just drain the water back out before winter. probaly will need flushed anyways
clean the points, throw a ballast resistor in the wiring to the coil temporary
leave the tweleve volt battery in it as it will spin it over a lot faster and yes the starter will take it
main thing is to get it running long enough to move it
drain the sediment bowel and blow air backwards threw the fuel line to the tank
fresh gas
tie it down good on the trailer
make sure the trailer is wide enough or be prepared to reverse one wheel to narrow it down
good luck
Ron
