Re: Questions about getting Grandpa's H to start
Posted by old on May 19, 2012 at 12:21:21 from (209.86.226.40):
In Reply to: Re: Questions about getting Grandpa's H to start posted by The Red on May 19, 2012 at 11:32:35:
6 volt coils only explode if you leave it turned on for a long time and not have it running but will last a very long time if you have it running BTDT many many many times over the years but also have had 2 or 3 explode when I left the ignition on and the engine not running. A trick to start a hard starting engine that has been switched to 12 volts if jumper the ballast resister out of the system to start it up then pull the jumper back off
