Sounds like you have a fuel issue; not getting enough. Maybe the carb float is set too low or more likely, you have some crud in the fuel tank and it is causing restriction of fuel flow. You may think you have everything clean, but it does not take much to cause problems. I could not get my U-2 power unit to start easy and run well until I put a fuel filter in the line. The fine crud was getting though the screen in the sediment bowl and causing carb problems. Since I put the fuel filter in the line, it starts when cold with no more than two or three pulls of the crank (it has a magneto and no electric starter) and after it's warm usually only one pull. I use NAPA 3032 fuel filter which has a metal case and is designed for gravity flow. The 3032 is for 5/16 fuel line. They also have the same filter for 1/4 and 3/8 fuel lines (different NAPA number).
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
