Re: 1945 farmall A
Posted by old on May 19, 2012 at 16:07:46 from (209.86.226.34):
In Reply to: 1945 farmall A posted by Pete60 on May 19, 2012 at 16:00:38:
Could be a spark problem or a carb problem. Start it up and run it till it dies. The moment it dies check for spark as in blue/white and will jump a 1/4 inch gap or more. If you have a good spark pull the carb drain plug and make sure you have a good steady flow of gas.
