Re: Hitachi Alternator Braket (Yooper Farmall?)
Posted by Janicholson on May 19, 2012 at 18:07:02 from (96.24.99.126):
In Reply to: Hitachi Alternator Braket (Yooper Farmall?) posted by kopeck on May 19, 2012 at 18:00:27:
Threaded rod doesn't spin my beannie either. A lonk bolt, and a pipe spacer looks good using the original bracket.
Putting it together with the threaded rod, then removing the bracket and remaking it to duplicate the offset would be pretty easy. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
