Re: 42 H PTO Leak Around Tail Shaft
Posted by The Red on May 20, 2012 at 03:03:25 from (69.246.205.0):
In Reply to: Re: 42 H PTO Leak Around Tail Shaft posted by Sapper55 on May 19, 2012 at 21:50:40:
You will want to point that downhill or you will have 90W pouring out! Another tip is to hold the PTO shaft as you pull off that seal carrier or the shaft might come with it. That happened to me on the Indy M and it was a bear getting back in!
