Farmall Tractors Discussion Board
Re: Talking about handcranking
Posted by Todd Markle on January 10, 1999 at 17:08:20:
In Reply to: Talking about handcranking posted by Kurt on January 09, 1999 at 10:18:43:
If the ignition timing is set correctly and the
impulse coupling in the mag is working it should not kick back. Every time I have ever had a tractor kick, I would check the timing and it was off. As breaker points wear the gap gets closer
which advances the timing. So you should check the point gap then check the timing. If the impulse coupling is working you will hear it clicking as you crank.
Post a Followup
: Re: Re: Talking about handcranking
