super A
Posted by Scott Blanchard on May 20, 2012 at 07:59:28 from (72.92.137.123):
I have a 51 super A that has been loading up, I cleaned the points and regapped, no good, messed with carb even swapped it with a BN carb I had that I knew worked and same result. Checked the gov. spring both are good. My plugs have a heavy carbon build up, not wet but not nice and burnt. I got the tractor from Ohio and it had champion D21"s, all my other farmalls use d18 the manual I have call for something different, What plug should I have and any ideas on what else I could check. Thinking I should do a compression check next.
