No, Farmall M's run just like the others, 540 at full engine speed but if you have an aftermarket 9 speed on your M, that will speed up the PTO and Lift-All system. Do you have or have you checked to see if it has a 9 speed in it? M&W's have a rod that goes to the right hand side of the tractor, just under the belt pully. You may be missing the rod or even the lever but would still see where they drilled into the side of the transmission.
If you are in high speed and getting high PTO speeds, you will be getting high ground speeds in 1st-4th gear as well so its pretty easy to tell that way too.
I think there are other manufactures of 9 speeds besides M&W and they used cables, maybe somebody that has one of those units will speak up and tell you where to look for them.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
