Posted by Janicholson on May 20, 2012 at 17:31:16 from (96.24.99.126):
In Reply to: 656 head or gasket posted by 34gpa on May 20, 2012 at 17:18:13:
If it is on the exhaust ports, and it is a diesel, it may just be slobbering. (normal if not worked hard) if it is real liquid oil, it is a head gasket. Short running times, and light loads in cool weather, make it worse. Drop aplow, or grinder into action for an hour or two and it will go away. If the manifold is loose, take it off and put a new gasket on it. Make sure the surfaces are clean and flat. Jim
