Re: Another 756 leak
Posted by mazemeister on May 20, 2012 at 18:40:57 from (24.187.98.163):
In Reply to: Re: Another 756 leak posted by The tractor vet on May 20, 2012 at 17:05:53:
course, if one is leaking, the other probably will before long. after all, they are almost 50 years old.
there are 3 o rings- 2 on one side and 1 on the other. i think the 2 are on the left. the 1 on the right is the same as the bigger one on the left.
to do all 3, drain the oil, pull the pto unit out, disconnect the draft control arm, then everything at the bottom is obvious.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
